05-07-2024, 07:53 PM | #1 |
39
Rep 40
Convertible mechanical maintenance...
Owner's manual doesn't say anything about regular lubrication or maintenance of the convertible mechanical joints.
Does any has suggestions about frequencies (once or twice a yr?) of lubrication? Where/which joints needs to be lubed? Pictures of locations, since there's dozens of posibilities... Best lubricants (WD-40?, etc.?) Thanks, |
05-08-2024, 08:27 AM | #2 |
4603
Rep 3,548
For the love of the car do NOT use WD-40 on anything of the top. If needed you want to use polytetrafluoroethylene in a bowl and use a small paint brush so to control the fluid and apply. I've looked at my top and have found no need to apply anything anytime soon. Now I do the weather stripping about once every three months, clean and lube bc of the AZ weather.
2022 M8 Comp Convertible
NavyBlue39.00 |
