03-09-2023, 06:37 PM | #1 |
12
Rep 25
Drives: 2019 BMW 850i 2dr Coupe 8cyl
Hello to all. Newcomer here.
I recently purchased this vehicle and decided I wanted to mod it. I installed the downpipes, intake, 2 step colder NGK plugs (Plugs were recommended to me) and all new Dinan Coil packs. Did not start or drive the vehicle until I applied the BOOTMOD3 tune. I sent my DME out to have unlocked so that I could apply a tune using BOOTMOD3. They came back today.I reinstalled the DME’s, put most of everything back together and began the tuning process. I chose the Stage 2 (non AGG). The flash was successful. Then came the issues after starting for the first time after all the upgrades. 1. After about 90 seconds of idling it started to drop RPM and then shoot back up consistently every few seconds. **I figured it just needed to idle for a while or be driven to kind of work out anything. So I decided I would take it out for a drive. I put it in reverse and the idling got worse to where it felt almost as if it wanted to stall out, but didn’t. I put it back in park as I was afraid something may be terribly wrong. As it remained idling for 5-10 minutes I noticed I had smoke coming out at my hood. Then I panicked and shut her down. I read that the smoke is probably due to the residue on the brand new downpipes? I popped the hood and she was definitely extremely hot! I squeezed the charge pipe hoses and they felt very soft. Normal? I then flashed the oem file back to see how she’d run normal without the tune. Same outcome of missing and carrying on. If I gassed it I had some popping out the exhaust to. So……..I’m thinking maybe the plugs? They were gapped at .19 new and that’s what one of the tuners in Cali said he does them at. So I didn’t change the gapping but checked them all before installing. I also wasn’t able to get the downpipes to go into the exhaust as far as the oem ones. I got them to the slit on the pipe and the c-clamp covered 1/2” opening that was left. I had a nightmares getting the oem plugs out and had to spend hours trying to get 5 out of the 8 out. I’m talking WD40 amd PB Blaster. By the time it was done I had tore all the rubber boot out practically. I also needed to remove the coolant tank to do the work and found that it had tipped over and leaked out. Nothing into the plugs directly though. I thoroughly blew out and dried up all the antifreeze the best I could. Any help would be great and thanks in advance. I previously had a 328i that a mechanic modded and tuned for me that blew 3 engines before I trashed it. So I’m quite hesitant to even start this $100k car again until I know what’s wrong. I’m not a mechanic or an engine head so I apologize in advance if my terminology/ verbiage is poor. I do not have any CEL at all. I did get some errors from BOOTMOD3 diagnostics though. That’s the latest but I had 4 or 5 related to misfire. cda73a, cda728, cda711 and cda73a |
03-09-2023, 08:30 PM | #2 |
The Wolf
256
Rep 992
Drives: stuff
I'd put the stock plugs and coils back in and retest... just my .2
03-09-2023, 08:32 PM | #3 |
12
Rep 25
I would but I threw them out instantly. Not to bright but I have ocd. Lol
03-10-2023, 11:41 AM | #4 |
33
Rep 19
Ok so bear with me as I am still learning about these cars. So from what I know there is a process you have to do before installing a tune. I only heard it in a video but I didn't pay much attention as I have no intentions of installing a tune myself...if anything my dealership does my tuning and the updates. But apparently if you do not do that process exactly as it is stated then there could be some issues. Again I didn't pay much attention. So I would ask you if you heard of those steps and if you did them accordingly?
My other suggestion is to ditch the coil packs and go back to the stock units. One thing I know from all the Domestics I have is that aftermarket coil packs some times cause issues. That is all I have to contribute. Good luck. |
03-10-2023, 12:36 PM | #5 |
406
Rep 421
Drives: BMW M4 Comp, 330i, Camaro SS
I would put stock coil packs back on, I'm not even sure why you changed them, it wasn't needed.
03-10-2023, 03:04 PM | #6 |
12
Rep 25
The coil packs were changed because I ripped all the rubber boots and they’re not sold individually. So I contacted a performance company and they told me that the Dinan would be an upgrade.
03-10-2023, 03:07 PM | #7 | |
4603
Rep 3,547
EDIT: My mistake its the injectors that need to be programmed..... Disregard.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0 2019 718 Cayman Base 2015 M235 Manual On the list for the M2 CS Last edited by Tenac; 03-10-2023 at 03:17 PM.. |
03-10-2023, 03:07 PM | #8 | |
12
Rep 25
03-10-2023, 03:11 PM | #9 |
12
Rep 25
Are there any diagnostics I can run to help with figuring it out?
03-10-2023, 03:14 PM | #10 |
12
Rep 25
03-10-2023, 03:18 PM | #11 |
4603
Rep 3,547
No my bad I made a mistake, injectors need programed not coils.
03-10-2023, 04:13 PM | #12 |
33
Rep 19
Ok so I found the video. Now I am not sure if this is a thing with EVERY tuner, but this was for Race Chips. To prep the car the guy says he had to put the parking brake on, open the hood, lock the car, and then remove the keys from the vicinity of the car.
Here is the video and it is at about the 2:50 mark. Again, I am not sure if this is only for RC and certain years or if it something you have to do with every tuner. Also this was a PB tune so I am not sure if this process also works with flashes. But it might be a good place to start looking. Another thing that crosses my mind...you did multiple mods at the same time so it might be difficult trying to find out what is causing the issue. I mean, it could also be something unrelated that might have happened during the installs. Maybe something wasn't connected properly or perhaps it is a corrupted tune. But since you put the tune back to stock and are still having these issues I would assume that it is the coil packs and plugs based on the symptoms. Smoke coming out from the engine bay...makes me think that the DPs are not fully connected properly or something is loose. The extreme heat from under the hood might be indicative of a collapsed cat (if they are HF catted DPs) or perhaps something is blocking the pipes. |
03-10-2023, 04:45 PM | #13 | |
12
Rep 25
03-10-2023, 04:47 PM | #14 |
4603
Rep 3,547
Have you contacted bootmod and the DME company yet? They typically can connect remotely to diagnose.
03-10-2023, 04:51 PM | #15 | |
12
Rep 25
“That’s not a tune or ecu issue. Something with your parts install. Plugs coils, vacuum leak” |
03-10-2023, 05:00 PM | #16 |
12
Rep 25
I don’t know if anyone will hear anything from these videos cause I’m almost deaf.
https://youtube.com/shorts/fPe-sHPdpG8?feature=share https://youtu.be/uW2ZzPIRrLo https://youtu.be/NoMtGe48VL0 |
03-10-2023, 05:04 PM | #17 |
4603
Rep 3,547
Yeah I'm not hearing anything wrong per say..... Maybe someone with better ears can chime in.
I think its 100% worth making sure everything is tight and installed correctly. IF that checks out you might as well bite the bullet and go back to OEM coil's.
03-10-2023, 05:05 PM | #18 |
4603
Rep 3,547
Maybe even try a different tune setting. You said you tried map 2, try some others too.
03-10-2023, 05:14 PM | #19 |
12
Rep 25
03-10-2023, 07:39 PM | #20 |
12
Rep 25
03-10-2023, 07:40 PM | #21 |
12
Rep 25
Would it cause a problem if the O2 sensors aren’t back where they were specifically? I’m only asking because I guess there’s a possibility I may have not put them back where they were.
03-10-2023, 08:12 PM | #22 |
4336
Rep 4,392
O2 as in oxygen? Take it with a grain of salt as I'm not a modder (yet) but that could be the likely suspect. Engine needs oxygen for the combustion so a faulty sensor or not where they should be could be an issue.
