09-17-2023, 12:24 AM | #24 |
22
Rep 25
Drives: M8 Competition Stage3
Hi,
I attached pictures then |
bloozemanAZ4305.50 Kansr164.50 |
09-22-2023, 07:00 AM | #26 |
22
Rep 25
I used bimmercode in expert mode for coding
02-21-2024, 08:35 AM | #27 |
Rep 2
Bowers speaker lights?
Hey guys, I was able to do the coding but found the bowers speakers stay on the original color unless I use the "white lightning" setting to force them white. Guessing there's another set of bytes somewhere. Anyone know where?
As an aside, It also appears from my experiments that the Group 1 color bytes control the door strips and center console strips, group 2 does the floor wells and group 3 is overhead map lights. Could be interesting the code in a 3 color scheme... |
04-18-2024, 07:12 PM | #28 |
165
Rep 192
*Edit….
After a few attempts was able to successfully code Red. As a note 345,8910,131415 was set to bronze in the menu and not white…in case anyone out there is having no luck.
Current: 2024 BSM M8
Retired: 2021 BSM M4 RWD Last edited by Kansr; 04-18-2024 at 07:36 PM.. |
04-19-2024, 02:09 AM | #29 |
399
Rep 464
04-20-2024, 04:14 PM | #30 |
4306
Rep 4,369
But that's just the door midrange drivers correct? I do not believe (or at least have not seen anyone with success) that can change the diamond tweeters in the door from anything other than the stock two colors which white is the best.
05-10-2024, 11:49 AM | #31 | |
Rep 16
Oh well. Side note, my friend also has the same year (23) M8 and for some reason his Bowers doesn’t even have the stock color match option. It’s only white lighting. I found that to be pretty weird. |
05-10-2024, 08:34 PM | #32 |
165
Rep 192
05-10-2024, 08:36 PM | #33 | |
165
Rep 192
Yesterday, 01:52 AM | #34 |
Rep 16
Yesterday, 08:20 AM | #35 |
399
Rep 464
Yesterday, 02:56 PM | #36 |
165
Rep 192
I’ll take a picture later tonight but I redid my bronze to solid red, and everything is red. I’m pretty sure I can any color and the speakers will also follow along suit.
@f92, that’s odd for sure does he for sure have B&W or HK? |
