03-06-2024, 05:48 PM | #46 |
15
Rep 3
Anyone notice that some of their driver assist features no longer work after this upgrade?
I have a 2020 M8C GC and now get warnings after every start that some driver assist functionality is compromised. Based on what I see on the parking cameras it is the side sensors that aren't working. |
03-06-2024, 07:48 PM | #47 | |
1592
Rep 4,554
Maybe try to disable then reenable DA functions in iDrive.
03-06-2024, 08:35 PM | #48 |
63
Rep 33
Of interest, my backup camera has changed. During daytime, it was super bright, almost like the gamma correction was too high. Just got home from work and it was almost useless backing into the garage. It was so dark, I could see maybe a car length behind me. Unless my backup lights stopped working, haha
03-06-2024, 09:44 PM | #49 | |
254
Rep 271
03-07-2024, 08:10 AM | #50 | |
268
Rep 852
No issues at all on my end!
03-07-2024, 08:42 PM | #52 |
The Wolf
256
Rep 992
Drives: stuff
Driven hundreds of miles and charged battery with trickle charger, still stuck on "we'll let you know when we can install" and RSU 038400 fault... Same happened on 3/2023 update and dealer had to perform and said known issue.
03-07-2024, 08:54 PM | #53 | |
1592
Rep 4,554
If your car has a bunch of coding, maybe try resetting back to factory defaults. Good luck.
03-07-2024, 10:01 PM | #54 |
40
Rep 13
Drives: 2023 M8 Competition Gran Coupe
New remote software upgrade US market - 11/2023.50
2023 M8 Competition Gran Coupe. Did the upgrade this morning. All went well, took about 40 minutes.
Had to reset all my personal settings in setup. It also reset my coded items to default. I was able to code everything back with no problems using Bimmercode. The only code I could not redo was the brake force coding, but at least I do not have the install message any more. |
03-07-2024, 10:32 PM | #55 | |
Extraordinaire
26
Rep 49
03-07-2024, 10:55 PM | #56 |
40
Rep 13
Yes, it no longer flashes while hard braking.
03-07-2024, 11:22 PM | #57 |
249
Rep 172
After multiple fails last year, over multiple version updates, I had to take the car to the dealer to get the update to work. I went from 07/2021 to 07/2023.58
Tech said there was nothing I did wrong. No battery replacement. Nothing about hazard lights. It was fixed free of charge. For those still having issues getting the install to complete, this is what the service record said: “CHECKED IN THE VEHICLE SETTINGS, UNABLE TO HAVE THE REMOTE SOFTWARE UPGRADE START - SELECTION REMAINS GREYED OUT AND NO FURTHER ACTION CAN BE TAKEN. CONNECT TO ISID TESTER, FAULT 038400 STORED - REMOTE SOFTWARE UPGRADE: VEHICLE-END PRECONDITIONS NOT FULFILLED. FAULT CURRENTLY PRESENT & HAS BEEN LOGGED 4 TIMES. WORKED THROUGH TEST PLAN: AT6510 SYS RSU - SYSTEM ANALYSIS. PROBLEMS WITH THE VEHICLE ENERGY RESERVE ARE IDENTIFIED. INSTRUCTED TO PERFORM ENERGY DIAGNOSIS, AND THEN TO PROGRAM THE VEHICLE. DIAG CODE: D8700 RSU00000 90 214. PERFORMED ENERGY DIAGNOSIS. NO IRREGULARITIES DETECTED, (D6121 00ENDIAG 70 901). STATE OF CHARGE IS 78%, NO INSTANCES OF CLOSED CIRCUIT CURRENT MONITORING AND AVERAGE JOURNEYS ARE NOT CONSPICUOUS. SWITCH TO ISTA/P, GENERATED MEASURE PLAN. PROGRAMMED AND CODED ALL THE CONTROL UNITS THAT POPULATE IN THE PLAN. PROGRAMMING SUCCESSFUL, INTEGRATION / SOFTWARE LEVEL UPDATED TO LATEST, OK.” Last edited by ikonn; 03-07-2024 at 11:30 PM.. |
03-07-2024, 11:27 PM | #58 |
249
Rep 172
So then I got the 11/2023.50 update notice a couple of weeks ago…the download went smoothly and the ‘Preparations for upgrade….you will be notified when the upgrade can be installed…’ message appeared, and….
It worked! Got the ‘ready for installation’ message today, and in 20 minutes, 11/2023 was ready. Now I just need to see what configurations were lost |
03-11-2024, 10:14 AM | #60 |
9194
Rep 7,770
I just got another upgrade notification yesterday although it was as I was leaving work so I just waved it off since I couldn't install it then. I thought I just got one. I see now checking the app its the .5 upgrade
03-11-2024, 10:17 AM | #61 |
9194
Rep 7,770
I can't imagine a 0.2 worth of upgrade does much, but does anyone have any idea what its supposed to do? I'm really not up for redoing all of my coding that I just re-did a week ago.
03-11-2024, 11:52 AM | #62 | |
1592
Rep 4,554
Is your coding so complicated that it will take you more than 15-20 minutes to restore? My take on this is BMW software engineers are working on fixes, improvements , etc. If they spend the time to do it for a 6 year old model nearing EOL, I will install it. So far it's working ok for me. No issues to report.
03-11-2024, 12:33 PM | #63 |
1381
Rep 733
I chose to apply the OTA update this past weekend. One positive benefit or strange coincidence: I run a catless system and my CEL went away.
In case anyone is wondering, I lost my custom coding, and I was able restore 90% of it thanks to Bimmercode. I'll have my local guy redo my ambient lighting and front lights amber delete.
'23 F93 M8 GC ZCP - HRE S101SC - Full Akrapovic - '15 Audi R8 4.2 S-Tronic (Past) YouTube '21 F96 X6M ZCP Akrapovic/MSS/BC Forged, ‘18 G30 M550i, '18 G01 X3 M40i, '15 F10 M5 ZCP HRE S101 #1 & #2/Akrapovic, ‘13 W204 C63 AMG - ADV1 5.01SL's |
03-11-2024, 12:40 PM | #64 | |
9194
Rep 7,770
claykin1591.50 |
03-11-2024, 12:47 PM | #65 | |
1592
Rep 4,554
1. Open Binmercode and make sure the latest database update is installed 2. I enable airplane mode on phone then re-enable wifi only 3. First I put the car in diagnostic mode. Then I manually connect to the MHD device wifi and have to force the connection since the phone sees no path to the web so it thinks I shouldn't connect to this network. Once I click to override it I'm good. 4. I proceed with Binmercode and all works ok.
snareman9193.50 |
03-11-2024, 12:52 PM | #66 | |
9194
Rep 7,770
claykin1591.50 |
