09-29-2020, 01:26 PM | #1 |
197
Rep 218
Drives: 2020 M850xi Gran Coupe
eSys Coding M850 - Saunders' Consolidated Coding Thread
Before I get started here, let me first get some forewarnings out of the way. It has been documented all over these boards that coding your car via either BimmerCode, MyCarly or eSys does not come without risk.
PLEASE DO YOUR RESEARCH BEFORE PROCEEDING! With that said, please resist from flaming this thread with warnings and advise for potential readers. I am advising right from the beginning here, if you do something wrong or attempt to code with incorrect versions or even with correct versions but different chassis vehicle, things can go wrong. If you move forward and are watching a video I've created and something on your screen doesn't match up with mine in the video, it's probably best advised to stop and restore the backup you created. Additionally, in the majority of these codes, credit is due to others in various BimmerPost boards and I am only testing them for validity on M850 vehicles before adding to the spreadsheet I created. For the most part, I parse the G05 & G20 chassis boards to see if there are coding options which can apply to the G14/G15/G16 chassis. Okay...now that all of that is out of the way... WHAT YOU'LL NEED TO GET STARTED OBD Interface Cable USB-C Ethernet Dongle (If you only have USB-C ports on your laptop) EsysX Standard 32/64 Bit On a MacBook Pro? No Problem! I used this 9to5mac video to create a dedicated external Windows Bootcamp HD for EsysX LINKS Here is the Google Sheet I've Created. This will continually be updated as I create new videos for each coding option I test on my M850. Saunders M850 Coding Spreadsheet Here is the three part series "Getting Started Coding the M850" I've created. (I am not a professional YouTuber nor do I aspire to be so the productional value will certainly reflect that) Part 1 - Downloading The Required Software to Code Part 2 - Installing The Required Software to Code Part 3 - Creating a FULL FULL Backup Before Starting to Code Part 4 - Suggested First Basic Code - Add B&W EQ/Sound Settings I suggest this as a first code as it is located within the RAM (Audio Module) of the HU_MGU ECU and is not as much of a critical drivability related ECU * If you already have B&W system, you can still use this video and just reverse the code to change to HK Logic7 for a good test first code * I have MANY additional codes to add to the spreadsheet, including some that are very popular on other boards, but I have not yet created videos for them. Also, I want to see how well received this thread is Some of these include aSLA (Automatic Speed Limit Assistant), HBA VLD (Anti-Dazzle High Beam Assistant), Modify Interior Lighting RGB Colors, etc... I should also point out that several of the codes I am looking at adding could also be coded via BimmerCode but this video series is intended more for those who want to explore eSys coding instead. ADDITIONAL CODING VIDEOS (See Links To Videos In Spreadsheet Above) Added 09/30/2020 - Automatic Start/Stop Memory (Remember Last Setting) Added 10/05/2020 - European Speed Limit Sign Graphics in Instrument Cluster Added 10/07/2020 - Automatic Speed Limit Assistant (aSLA)
Current Ride
2020 M850xi Gran Coupe Previous Rides 2019 X7 / 2018 X5 / 2012 X5 / 2014 750xi / 2011 750Lxi / 2008 335xi Last edited by Saunders17283; 10-07-2020 at 12:15 PM.. Reason: Added More Coding Content |
11
FBMWWINS604.50 redhot47fla769.00 Ozzie8641.00 BMWCARGUYM5X559.50 BeeMdblU452.00 ifr1201.50 BigMofoFrog183.00 Tenac4575.50 nynd174.50 Andycam55.50 gennaroanesi152.50 |
09-29-2020, 09:33 PM | #2 |
452
Rep 859
That's awesome Saunders, thank you so much for creating this thread and sharing coding with us, it's a rarity when it comes to these series, so much appreciated.
Saunders17283196.50 |
09-29-2020, 11:59 PM | #3 | |
197
Rep 218
Thanks, BeeMdblU!
Current Ride
2020 M850xi Gran Coupe Previous Rides 2019 X7 / 2018 X5 / 2012 X5 / 2014 750xi / 2011 750Lxi / 2008 335xi |
09-30-2020, 04:06 PM | #4 |
605
Rep 909
Great thread for me as I LOVE coding and like to experiment with that too (at my own risk of course!). Thanks Saunders for taking the initiative and the time to do this.
You nailed the important points that are well thought out and explained. I believe this is a great format. If you want, agree, users could post here what has actually worked for them on their G14-G15-G16 M850i model with the detailed coding that was performed and specifying the tool used (so we know it works for sure) since some options may not be codable or doable via apps..... Then you can take each one and add it to the spreadsheet and further consolidate that. At the same time, along with the spreadsheet, users may find great interest in reading what everyone have coded and get that experience shared here - of course granted it has worked as intended. It would be great to share that input as well as being able to download the file for our own reference/editing and adjustment. Just my 2 cents. Last edited by FBMWWINS; 10-01-2020 at 04:19 AM.. |
09-30-2020, 06:57 PM | #5 |
197
Rep 218
Added New Video To Spreadsheet
- Auto Start/Stop Memory (Remembers Last Setting)
Current Ride
BeeMdblU452.00 |
09-30-2020, 10:07 PM | #6 |
4316
Rep 4,377
Saunders17283 Thank you so much for putting this together! I've been hacking and modifying firmware, software, etc. for close to two decades now but all on less costly devices than my 2020 M850i. On the rare occasion I've bricked a cell phone, network router, etc. but they are easily replaceable. I fully understand the disclaimers you put forth but the knowledge shared including the video tutorials provides me with the confidence to give it a go.
That said I had already watched the first two videos thanks to your private preview on installing the software, etc. Thus, over this past weekend I pulled an older HP laptop out of storage that has an onboard ethernet port, upgraded the Win7 on it to Win10 and am ready to do the software install later this week. (Side tip to anyone still having a Win7 system the free upgrade from MS is still alive and well although it officially ended quite some time back.) I just watched the training wheels video on adding B&W EQ/Sound Settings and figured per your recommendation that is what I'll try first. However, I'm not sure what that does whatsoever so can you explain that? The reason being is I'm an audiophile and have spent months dialing in the EQ settings to deliver the glorious B&W sound that is one of my favorite aspects of the car. |
10-01-2020, 12:25 AM | #7 | |
197
Rep 218
The video "Adding Bowers & Wilkins EQ/Sound Settings" is just a "dip your toe in the water" video. It doesn't accomplish a ton but allows you to try your first code on an ECU without drivability implications. If you already have a B&W system, you would be reversing the process outlined in my video...which is to say, you'd "dip your toe" by coding the following: AUDIO_SYSTEM alev4_Ram (B&W EQ) > AUDIO_SYSTEM alev3_Ram (HK EQ) Basically since you already have B&W, this means your factory setting in AUDIO_SYSTEM would already be set to alev4_Ram so to do a simple "dip your toe" code, you could code to alev3_Ram. Of course you could easily go back and reverse it 30 seconds later after verifying it worked in your car. My car unfortunately doesn't have B&W however this attached pic shows my iD7 after the code. When I coded from HK to B&W setting, my EQ remained untouched. This is not a guarantee it works the other way but I can only state that I did not lose my EQ settings. You may want to make a note prior to coding though. (i.e. 80Hz +1, 120Hz +5, etc......)
Current Ride
BeeMdblU452.00 |
10-01-2020, 08:14 AM | #8 |
197
Rep 218
Added some additionally requested "Getting Started" links for OBD cable, etc... and coding from a MacBook Pro
Current Ride
BeeMdblU452.00 |
10-01-2020, 06:26 PM | #9 |
197
Rep 218
Added a new part 3 which outlines a thorough way to create a FULL backup in case anything gets messed up in the future.
Current Ride
BeeMdblU452.00 |
10-01-2020, 09:21 PM | #10 |
452
Rep 859
Hey Saunders how fast was esysx delivery? and can you try coding european speed limit sign please, I believe @Bigmofofrog did it in m850, it's under Kafas module
10-01-2020, 11:01 PM | #11 | |
4316
Rep 4,377
That said as per your explanation enabling the iDrive interface for the B&W settings is an interesting angle for an owner with HK. In other words I'm curious as to whether the "sound profiles" aka DSP settings are indeed active regardless of B&W vs HK hardware. If they are that is a total plus for anyone with HK outside of the fact that the crossovers (which drive the frequencies targeted per speaker) are still hardware wise different from a B&W vs HK build. |
BeeMdblU452.00 |
10-02-2020, 01:22 AM | #12 | |
197
Rep 218
Current Ride
BeeMdblU452.00 |
10-02-2020, 01:26 AM | #13 | |
197
Rep 218
I think I paid via PayPal in case that matters. I will add EU speed signs to my queue for certain!
Current Ride
BeeMdblU452.00 |
10-02-2020, 03:04 PM | #14 | |
452
Rep 859
10-02-2020, 03:06 PM | #15 | ||
197
Rep 218
Standard is fine though as far as I know.
Current Ride
BeeMdblU452.00 |
10-02-2020, 03:10 PM | #16 | |
605
Rep 909
https://esysx.com/licenses/ For simple coding stuff the STANDARD license version is just fine. Last edited by FBMWWINS; 10-02-2020 at 03:21 PM.. |
BeeMdblU452.00 Saunders17283196.50 |
10-03-2020, 12:01 PM | #17 | |
197
Rep 218
KAFAS4 > CAFD 40F8 > 3003 > COUNTRY_CODING_DISPLAY > ECE white I will test this and if it works, publish a video for it in my spreadsheet.
Current Ride
BigMofoFrog183.00 BeeMdblU452.00 |
10-03-2020, 10:59 PM | #18 | |
452
Rep 859
Also thank you to BigMofoFrog for bringing it out to my attention. |
BigMofoFrog183.00 |
10-05-2020, 10:13 AM | #19 | |
197
Rep 218
Current Ride
10-05-2020, 03:44 PM | #20 |
452
Rep 859
Thank you Saunders I did it yesterday, followed your videos for some tips.
Saunders17283196.50 BigMofoFrog183.00 |
10-07-2020, 12:18 PM | #21 |
197
Rep 218
Just added to spreadsheet - YouTube video and coding for aSLA (Automatic Speed Limit Assistant). This is a super cool one which I have gotten quite accustom to using.
Current Ride
10-07-2020, 04:01 PM | #22 |
184
Rep 224
