03-11-2024, 10:24 AM | #1 |
9201
Rep 7,780
Enabling Anti-Dazzle with Bimmercode - Easy
This is from the X3 forum, but I also made the same change on my M8 and it seems to have worked. You literally only have to change one setting since the other seems to be already set. I'd be curious to know if in the end this produces the same results of using eSys. But here you go if you want to give it a try...
To ENABLE Anit-Dazzle: Using Bimmercode EXPERT MODE Under Body Domain Controller 3532 LaMaster3 C_HBA_ENA> enable (Should already be set to ENABLE) if you have previously done the factory software update. C_HBA_GFHB_ENA>enable That is it. Keep in mind that in order for the Anti-Dazzle to work the following things must be true: --Auto High Beam button must be ON and active --Must be going over 37 mph which is the point in which Auto High -------Beam activates High Beam --Must be dark enough outside for AHB to function --If you are below 37 mph and want to manually use High Beam you can but it will blind people in front of you since Anti-Dazzle won't be functioning. --Also, if you use the Manual High Beam you will disable Anti-Dazzle until you turn the manual high beam back off. If set correctly with AHB will turn your blue High Beam light will remain on while you are behind vehicles or if they are approaching you. Here's the original thread https://x3.xbimmers.com/forums/showthread.php?t=2064462
03-11-2024, 01:42 PM | #2 |
1381
Rep 733
Thanks for sharing! I'm going to try this later.
'23 F93 M8 GC ZCP - HRE S101SC - Full Akrapovic - '15 Audi R8 4.2 S-Tronic (Past) YouTube '21 F96 X6M ZCP Akrapovic/MSS/BC Forged, ‘18 G30 M550i, '18 G01 X3 M40i, '15 F10 M5 ZCP HRE S101 #1 & #2/Akrapovic, ‘13 W204 C63 AMG - ADV1 5.01SL's |
03-11-2024, 07:30 PM | #3 |
1381
Rep 733
I coded it as explained above by Snare.
Due to my urban environment, it's not easy for me to determine if my high beams are actively moving and masking itself as intended. The cut-off line based on the car in front of mine seems to be normal with the new config. However, I did get high beamed by an oncoming car which caused me to abort the experiment. When I go see my sis out east one day soon, I'll give it another stab. Thanks again!
03-11-2024, 07:48 PM | #4 |
9201
Rep 7,780
I haven't been flashed in either car since I did the coding. Here are some pics I took of the light tunneling with my X3. I'd say overall the feature as it seems to be working is a bit more of a novelty than overly practical, but I still like it. Which is also part of what makes me wonder if coding with eSys would have any better/different outcome.
https://x3.xbimmers.com/forums/showp...5&postcount=91
ed41381.00 |
03-12-2024, 06:46 AM | #5 |
267
Rep 166
Well there's actually more to fully enable anti-dazzle:
BDC Body Domain Controller LUT_AFS_CODRV_HOR standard/init BDC Body Domain Controller LUT_AFS_DRV_HOR F040_G005_AHL... BDC Body Domain Controller LUT_FLC_FORWARDLIGHTING_Y AFS BDC Body Domain Controller C_AFS_ENA aktiv BDC Body Domain Controller C_AFS_ECO_LEVEL_3_ENA enable (1) BDC Body Domain Controller C_HBA_ENA aktiv BDC Body Domain Controller C_HBA_DIM_ENA enable (1) BDC Body Domain Controller C_HBA_GFHBA_ENA_V_HI standard (3C) BDC Body Domain Controller C_HBA_GFHB_ENA aktiv BDC Body Domain Controller C_CLC_CURV_V2 ECE (23) BDC Body Domain Controller C_CLC_CURV_V3 ECE (28) BDC Body Domain Controller C_CLC_EXT_ENA enable (1) BDC Body Domain Controller C_FLC_ENA aktiv BDC Body Domain Controller C_BLC_PRE_ENA enable (1) This is only accessable via ProTool: KAFAS4 3100 COMMON COUNTRY_VARIATION Europe_RC [01] KAFAS4 3102 LIGHT DETECTION C_FLA_CC_MESSAGE_3 no_CC_message [00] KAFAS4 3102 LIGHT DETECTION C_FLA_COUNTRY_WITH_MULTIPLE_REFLECTORS active KAFAS4 3102 LIGHT DETECTION C_FLA_US_SENSITIVITY_MODE normal [0] KAFAS4 3102 LIGHT DETECTION C_FLA_BS_ENTER_THRESH Rest of world [03) KAFAS4 3102 LIGHT DETECTION C_FLA_BS_EXIT_THRESH Rest of world [02] |
03-12-2024, 07:35 AM | #6 | |
9201
Rep 7,780
03-12-2024, 11:21 AM | #7 |
Permanently confused
1169
Rep 1,706
As a UK owner that has a 840i with anti dazzle from the factory that works like a dream I can’t help wondering if, based on the comment above about being ‘flashed’ by an oncoming car, it is set up for those us that drive on the correct side of the road and might work ‘the wrong way round’ for those that drive on the left.
Mine is switched on permanently and once all parameters are met it fires up and works beautifully, lighting verges, main beam on even when car coming in opposite direction without causing them problems, illuminating motorway signs, etc. Fantastic bit of kit. Last edited by Seaford; 03-13-2024 at 01:41 AM.. |
03-12-2024, 07:33 PM | #8 |
9201
Rep 7,780
This was on my ride home tonight so it definitely does something but like I said I'm curious of this simple fix compared to the official coding. I have a local friend that can do real coding so I'm going to try and get with him and see if I can tell a difference
03-12-2024, 08:21 PM | #9 | |
9201
Rep 7,780
03-13-2024, 09:53 AM | #10 |
655
Rep 1,602
I retrofitted the Euro Spec Laser lights in my X5M50i and had them coded appropriately. I also had the anti dazzle coded in the M850i by someone locally.
While it works a little better than stock, the Euro version is definitely a lot better in how it cuts around other cars. |
03-30-2024, 04:51 PM | #14 |
191
Rep 356
So, on my M8 I did this today using ProTool, it's still light out so I haven't tested it but I did notice that when in Auto lights, the Auto High beam button no longer activated when you push it the icon doesn't show up like it did before. Is this normal since the system will just run anti dazzle now?
03-30-2024, 11:00 PM | #16 |
191
Rep 356
Yeah it just needed to be dark for that button to work.. but I can not get Anti Dazzle to work.. one problem is I can't find Kafas4 I found it before but it can't remember how, it isn't in the ECU list.
03-30-2024, 11:19 PM | #17 | |
191
Rep 356
Update: went for a drive from Fort Worth to Dallas, the high beams come on and stay on alllllot more. I noticed they would shut off as I passed a car and would come right back on.. since the highway is well lit I couldn't see a big difference.. maybe I'll go for a drive in the county tomorrow. |
03-31-2024, 11:04 AM | #18 |
64
Rep 151
You will notice if anti-dazzle is working, it really is a dynamic lighting system.
You will see lights shutting on and off quickly in various spots in the light field. I don't think you have anti-dazzle working yet, there is a noticeable difference between the two. |
KevinGS3378.50 |
04-27-2024, 08:23 AM | #19 | |
65
Rep 24
Anyone know if this list of codes get the designed functionality while 5AP remains? I'm considering doing this to my 23 M850. I'm wondering if removing 5AP has any long term impact with some future OTA being rejected or maybe something at the dealership that the car no longer matches the build sheet, some kind of VIN tracking or something. |
