03-15-2024, 01:07 PM | #1 |
38
Rep 53
Flex Disk replacement
Hi all, recently got recommended to replace my flex disk attached the image. It’s not covered under the platinum extended warranty given the wear and tear nature of it. They are quoting around $2k for the repair. Not sure if I should go independent for this
03-15-2024, 02:21 PM | #4 |
4603
Rep 3,548
2k !!!! holy crap How much was the part cost? I find BMW drive train specially the drive shafts are super simple and east to to work with. I would recommend getting quotes at independent shops for sure. I couldn't imagine up on a lift it taking more than 2-3 hrs... Hell I just took one off my project 235 and dropped the fuel tank in under 3 hrs.
2022 M8 Comp Convertible
03-15-2024, 02:48 PM | #5 |
319
Rep 1,018
I don't feel like that's a wear and tear part; it's not something I would expect to have to change during the warranty period on any car without an abuse component precipitating it.
Is that their claim? |
03-16-2024, 01:16 AM | #6 |
110
Rep 153
Are you feeling anything in the drivetrain as you drive, how does the car feel?
2020 BMW M850 Gran Coupe
2019 LR Discovery HSE 2009 BMW 650i Cabrio 1999 Mercedes SL500 1980 Mercedes 450SL |
03-16-2024, 05:58 PM | #7 |
38
Rep 53
03-17-2024, 09:13 AM | #8 |
Rep 13
Hi,
there is no need for a new flexible disc. It is only the outer rubber. The core is surely fine. Please have also a look to the BMW document. |
03-17-2024, 01:03 PM | #10 |
38
Rep 53
03-18-2024, 09:05 AM | #11 |
285
Rep 81
Drives: 2023 M850
Everything you ever wanted to know about BMW flex discs. We had one replaced in my wife's z3 many years ago. 2k sound about right given the cost of labor now days. The part is not very expensive but typically lots of things need to be removed or loosened before you can actually start replacing the disc.
https://eeuroparts.com/blog/drivelin...he%20driveline. |
03-18-2024, 06:48 PM | #12 |
1292
Rep 1,658
I'm finding the bmw platinum wrnty isn't quite as good as I had thought
03-18-2024, 08:23 PM | #14 |
1292
Rep 1,658
As do I. I’m sure it does what it’s supposed to but it’s well shy of the new car one. I had leather raise up under rear side window and it wasn’t covered, but bmw did goodwill since my 19 only has ~6k miles. It’s an example like this of the platinum that concerns me.
