10-23-2022, 05:11 PM | #46 |
4340
Rep 4,398
Checking the owners manual for my 2020 M850i it has literally zero information on the number of batteries, where located, etc. Does indicate that if the battery is replaced that it needs to be registered to the car to enable comfort access, etc. Only terminals it calls out for charging or jump starting are under the hood.
Tenac4604.00 |
10-23-2022, 05:14 PM | #47 |
4340
Rep 4,398
10-23-2022, 08:41 PM | #48 | |
1292
Rep 1,658
10-23-2022, 08:44 PM | #49 |
4340
Rep 4,398
11-01-2022, 01:21 PM | #50 |
613
Rep 537
Had my break in service done today so I asked master technician the same question.
'M8 has only one battery, it's LiON, cost $1200+, located under the trunk floor and if you don't drive enough to charge it recommended to put on LiON charger using under the hood connect points' |
M8Bimmer1299.50 |
11-02-2022, 03:51 PM | #51 |
4539
Rep 7,590
BMW warns against using the 12 volt (cig lighter sockets) because they are on a relay and will shut down after a few minutes. If you're using the 12v sockets to charge...then the charger will also be cut off from doing it job.
The car will have a dual battery setup (aux battery) based on options. The aux battery usually is installed if you have active integrated steering or its used to helpw with EPS (electronic power steering). If you have an auxiliary battery, it is maintained by either a PCU (power control unit) or a charging controller. Use the dedicated jump start terminals in the engine bay for maintaining the car's main battery. The PCU or charging controller will take car of the aux battery.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-02-2022 at 03:58 PM.. |
Tenac4604.00 |
03-11-2023, 12:02 PM | #52 |
1444
Rep 1,121
Drives: 2022 M8cs
All great info here. This battery is 2500 CND so Canadians not driving in winter be aware. I start mine every two to three weeks, but she’s dead this morning. Trying the charger route first.
03-11-2023, 02:05 PM | #53 |
1444
Rep 1,121
Drives: 2022 M8cs
Got her going. Around the block a few times. These pilot alpines not too bad Last edited by Dr Thrillride; 03-11-2023 at 02:45 PM.. |
03-12-2023, 09:17 AM | #54 |
613
Rep 537
Trying to drive 10-20 miles per week when weather is nice enough. So far battery keeps up nicely and I'm pleasantly surprised by BMW engineering specially when compare with horror stories from new SL R232 forum. Also the JBV1 app shows battery voltage and it really helps to monitor battery status.
03-12-2023, 10:51 AM | #55 |
1292
Rep 1,658
BMW established and provided a protocol on how to keep the battery and the car healthy during the peak Covid. It applies here as well
Here’s the UK version, can’t seem to locate the US one, but they’re similar I’m sure. https://discover.bmw.co.uk/help/owne...nt-Coronavirus
12-11-2023, 10:45 AM | #56 |
Rep 1
I believe the second battery is a requirement for the driver's assist package to steer the car in an emergency situation where the main battery fails.
02-18-2024, 10:05 PM | #57 |
Extraordinaire
26
Rep 49
Do you know if anyone has tested the weight savings over the 70 Ah Li-ion and a 70 Ah AGM BMW would use?
02-19-2024, 08:56 AM | #58 |
4604
Rep 3,551
Not that I have seen. But the location of the battery is a good spot to have some heft, very low and just past the rear end. Good for traction there.
2022 M8 Comp Convertible
