BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion eSys Coding M850 - Saunders' Consolidated Coding Thread
      08-11-2022, 03:02 PM   #45
Almaretto
Almaretto's Avatar
2376
8,364
Drives: Test Vehicles
Originally Posted by darkdoubt View Post
Anyone coded augmented reality yet?
It's in HU_MGU 3013 Augmented Reality
Seen it done on earlier chassis, but not yet on newer.
      08-21-2022, 03:38 PM   #46
darkdoubt
17
13
Drives: 2021 M850
Thanks for the link Almaretto,
Looks like all of those features are standard o my '21 m850.
      09-07-2022, 07:52 AM   #47
fmzip
Spoiler Bandit
fmzip's Avatar
1653
872
Drives: 2019 M850i / 2016 228i
I enabled assisted Drive view, Sport Expert mode and Comfort Plus in Bimmercode expert mode if it's helpful to anyone:
https://f92.bimmerpost.com/forums/sh...php?p=29304020
      12-01-2023, 06:47 AM   #48
Westy
Westy's Avatar
United Kingdom
162
92
Drives: G15 M850i
Has anyone got any advice for changing the scale on the sports display (power and torque).
Since my remap it just maxes out immediately and desperately want to alter the scale so it makes sense again!
I’ve got BimmerCode with OBDLink CX.
      12-31-2023, 09:49 PM   #49
Dasky_spas
148
552
Drives: Bmw
Do you have lines to get rid of the active shutter?
      01-05-2024, 10:45 PM   #50
TheNine90
582
2,047
Drives: bmw
should be akks or lks
      01-06-2024, 01:21 AM   #51
Dasky_spas
148
552
Drives: Bmw
I had this done, 'coded' out by tuner successfully (or so it seems) but now the radiator fan is not coming on after the car shutdowns, which is used to do every single time.
      01-07-2024, 02:52 AM   #52
TheNine90
582
2,047
Drives: bmw
Could be tuner affected the cooling maps. It might also be the flaps delete has more cooling effect that doesnt need to turn on the radiator fan.
      02-13-2024, 07:47 AM   #53
B. ADA
10
Drives: bmw 8.40d gran coupe
Bmw g16 BLINKER_VOLUME of the turn signal / close or change
Dear All,
Is it possible to change or cancel the signal sound that occurs in the BMW G16 2020 when turning left and right? THIS clicking sound is driving me crazy.
Thank you in advance,
      02-14-2024, 10:44 AM   #54
eldyf93
Extraordinaire
26
49
Drives: F93
Originally Posted by B. ADA View Post
Dear All,
I was just looking at the coding options last night and yes this is possible.
      02-20-2024, 08:23 AM   #55
B. ADA
10
Thank you for your answer.
I found someone using e-sys, it was connected to my vehicle, yes, as you said, there is such an option, but even when we reduce / or cancel the volume in the option, the signal volume and level do not change at all. Is there a more obvious option or another way?
I thank you in advance for your answer.
      02-20-2024, 11:50 AM   #56
eldyf93
Extraordinaire
26
49
Drives: F93
Which ECU and NCD are you editing?
I didn't try the setting on my S18A F93 as I want to have the turn signal sound.
      02-28-2024, 02:41 AM   #57
B. ADA
10
Signal sound / cancel /b change of bmw 8.40d-2020
We made combi and NBT arrangement.
What method should we use to change, reduce or cancel the signal sound we use when turning left and right?
      03-21-2024, 07:14 AM   #58
B. ADA
10
Has anyone found a way to cancel or change the signal sound when turning left and right in the BMW G16 series? BMW seems to have prevented this, but you know, hand beats hand.
      03-21-2024, 07:25 AM   #59
B. ADA
10
Has anyone found a way to cancel or change the signal sound when turning left and right in the BMW G16 series? BMW seems to have prevented this.
I connected via e-sys and changed it, but bmw doesn't keep it. Does anyone know a way please. This beep is driving me crazy. "This is a plea."
Thank you in advance!
Kind regards,
      03-24-2024, 04:40 AM   #60
Z4WK
Z4WK's Avatar
Drives: BMW Z4 G29 M40i
Kind regards,
Just coded it in my MY23 G14 (using Bimmercode it is very easy, but then it must also be possible using Esys I assume). You can choose between BMW, BMW 2021 (much softer), Mini or RR sounds.
Worked also in my MY22 G29.
      03-24-2024, 06:42 AM   #61
yugrac
yugrac's Avatar
157
117
Drives: 2022 BMW M850i Convertible
Please share a few more specifics, like which ECU module, etc. Thanks
      04-20-2024, 06:36 PM   #62
oztwix
16
Drives: 2018 M550
I can't find the bimmer code tips in the thread you linked. Can you link the specific page or direct message it to me? Thanks so much!
