01-01-2023, 11:03 PM | #24 | |
9253
Rep 7,827
FlorinQCK-2.50 |
04-22-2023, 06:13 AM | #25 | |
221
Rep 93
Drives: 2023 BMW M8
Thanks! |
04-22-2023, 01:42 PM | #26 | |
4336
Rep 4,392
I could have done all the settings from the actual EQ flat but that would have taken more work plus starting with the bass it was easier to just go by the "box" and red line. Hope that helps. There are older photos of the EQ floating around but I'll take a new one and add it to the thread so you can get an idea of how the boxes and red line looks when done. Edit... attached latest pic so you can see how the boxes and redline make the settings vs true flat on the EQ. Only true flat on the EQ is treble as you don't need to boost that at all with the diamond tweeters. |
04-22-2023, 02:47 PM | #27 | |
221
Rep 93
Drives: 2023 BMW M8
Awesome - Thank you! |
04-22-2023, 02:48 PM | #28 |
4336
Rep 4,392
04-22-2023, 03:14 PM | #29 |
221
Rep 93
Drives: 2023 BMW M8
04-22-2023, 03:44 PM | #30 |
4336
Rep 4,392
Looking forward to hearing the results. That EQ, bass trim on +6, treble trims flat and the Concert sound profile and 40% plus volume should end up with a sound panorama in the cabin of pure glory. Only caveat may be if you're in a GC vs a coupe as that may take some tweaking given the cabin size differential. Odds are though it should work amazingly well even for a GC but some tweaking could improve that.
04-29-2023, 06:19 AM | #31 | |
221
Rep 93
Drives: 2023 BMW M8
05-22-2023, 10:31 AM | #32 |
Rep 3
Hey man, saw your posts and had a quick question. It would be great if you could help me with this.
I have a 2021 BMW M8 Comp GC with the HK and obviously want to upgrade it. From my research on your posts, and having spoken with several enthusiasts, Bavsound or Bimmertech seem to be the easiest compatible way to go. Unfortunately, no amp with either companies has been released yet for this model. Can you recommend an amp that can work with Bavsound speakers or recommend anyone who can offer a solution? Thanks! |
05-22-2023, 03:20 PM | #33 | |
4336
Rep 4,392
That said the only amp on the market that supports iD7's OABR network that I'm aware of is the Audiotec Fischer MATCH UP 10DSP. The naming convention dictates DSP as it overrides the car's HK (or B&W but nobody in their right mind would do so) DSP once in place. The confusion may lie in that it is indeed an amp as well and a few fellow forum brethren have deployed it to replace the HK (aka standard RAM booster) with full success. Audiotec Fischer also makes speaker replacements but nothing for the 8-series. That is where Bavsound or Bimmertech come into play with the goto being the former and a fallback being the latter. |
05-23-2023, 12:36 AM | #34 | |
Rep 3
Any link on where to purchase the B&W speaker covers would be helpful. Thanks! |
05-23-2023, 07:09 AM | #35 | |
157
Rep 117
https://f92.bimmerpost.com/forums/sh...1935351&page=5 |
bloozemanAZ4335.50 |
05-24-2023, 07:19 PM | #36 | |
4336
Rep 4,392
